The inlet pushrod cam follower on my engine appears to have disappeared. I se the tappets after finding a large gap. A week later the large gap was bsck so I took off the head to find that that particular pushrod much lower than the rest. What could be the problem
4 replies to this topic
Posted 24 October 2019 - 07:16 PM
Posted 24 October 2019 - 07:20 PM
Worn follower/cam lobe
Posted 24 October 2019 - 07:54 PM
Time to strip the engine.
Posted 25 October 2019 - 08:11 AM
Broken push rod maybe
Posted 25 October 2019 - 08:54 AM
What engine? If it's a small bore you might be able to take the tappet covers off and see if the follower has moved ..
Mini Technical Sections →
Problems, Questions and Technical →
Piston Rings - A-Series 998 Engine - Help RequiredStarted by WanaGo , 18 Apr 2024 engine |
Exhaust Choice 45Dcoe - Rc40?Started by lachlan1275gt , 13 Apr 2024 engine |
1071 Main Bearing Caps.Started by 246jaenick , 02 Apr 2024 engine |
Misfire - Ignition Fault Or Fuel Problem?Started by derekaka2sheds , 01 Apr 2024 electrical, engine |
Which Rocker ArmsStarted by mark the diver , 30 Mar 2024 engine |
