Coolant Expansion Tank Hose
6 replies to this topic
#1 splintercat
splintercat
  • 616 posts
Posted 27 October 2019 - 04:34 PM
revamping the cooling sytem/radiator on my car. have a front radiator set up. re-jiggling the hoses is a nightmare, however, I have resited the expansion tank to the inner wing and now due to the radiator that I have I need to fix the expansion hose to the top hose somehow. I know that I can buy an inline set up which includes a radiator cap/filler with a connector for the expanson tank but I do not have the room. I have heard that I can buy a fitting that just screws into the top hosefit fot this purpose but cannot for the life of me find one or find out its' name?
I can buy an in-line adapter suitable for a temperature/auxilary sensor but don't know if I could adapt it fit for purpose?
#2 nicklouse
  • 19,062 posts
Posted 27 October 2019 - 04:39 PM
what is wrong with using the existing take off as that is the highest point of the system and that is where it should be taken,
#3 splintercat
splintercat
  • 616 posts
Posted 27 October 2019 - 06:07 PM
the existing take off was from my previous radiator alongside the rad main filler, my new alloy 40mm rad has no filler cap, just a top hose connector and a bottom one.
I did think about buying an in-line sensor adapter, which you just cut into the top hose as it has a threaded connector in it, this is an 1/8 NTP thread for the sensor , but then I would have to buy another fitment......ie 1/8 NTP male at on end and then with a 6-10mm barbed male at the other but all sounds too  complicated...just thought that someone has come across one of thses screw in self sealing adapters to make it a little easier.
#4 Ethel
  • 26,799 posts
Posted 27 October 2019 - 06:27 PM
What sort of expansion tank?
I'm assuming if there's nothing on the rad it'll also be the filler and not an overflow tank. I'd expect  there to be a connection tee'd off the heater to bottom hose plumbing along with an air bleed that could be  taken care of with a Metro or MPI thermostat housing.
#5 nicklouse
  • 19,062 posts
Posted 27 October 2019 - 07:09 PM
best out of the thermostat housing
yes see my thread last few pages. but you still need the bleed hose from the highest point.
#6 nicklouse
  • 19,062 posts
Posted 27 October 2019 - 07:21 PM
just to help
#7 splintercat
splintercat
  • 616 posts
Posted 28 October 2019 - 01:41 PM
just to help
Nice one mate....just what I were looking, you're a gentleman and a scholar, thank you xx
