Brake Master Cylinder Dangerous And Not Happy
7 replies to this topic
#1 Shooter63
Shooter63
  • 1,299 posts
Posted 27 October 2019 - 05:38 PM
About 18 months ago my Mrs mini master cylinder started to go, ie pedal would slowly go to the floor with continuous pressure, minispares were out of stock so I ordered it from somewhere else, please note this was a so called genuine AP green tag job not a cheap copy. Well over the last few months I've noticed that I had to top up the brake fluid rather too much for the miles the car was doing, I did the normal checks, calipers dry, rear bake plate dry, all hoses and pipes dry hmmmm me thinks, so I take off the hose at the servo and brake fluid poured out, deep joy. To say I'm unimpressed is an understatement, if this wasn't a family forum this post would be full of #### etc. Not only is this extremely poor quality but bloody dangerous.some poor sod some where will have a serious accident due to shoddy vital parts and sue the butt off of the offenders perhaps then we shall see the end of these sub standard so called genuine parts these companies are getting made. Too many so called top end companies are now getting there parts made off shore as cheaply as possible, it's got to change
Shooter
#2 Spider
  • 15,878 posts
Posted 27 October 2019 - 06:56 PM
There's been a recall on some Brake Master Cylinders
http://recall.920e.co.uk/
920e is the new name (effectively) of Caparo who took over the manufacturing of AP Cylinders
#3 Dr s
Dr s
  • 428 posts
Posted 29 October 2019 - 04:54 PM
That sounds like a servo problem to me? The master isn’t losing fluid? It’s just in the servo?
#4 sonscar
sonscar
  • 3,257 posts
Posted 29 October 2019 - 06:08 PM
Fluid is leaking out of the cylinder into the servo,op says he is topping it up,Steve..
#5 Chris1275gt
Chris1275gt
  • 1,054 posts
Posted 29 October 2019 - 06:41 PM
If a hose on the servo that doesn't normally have fluid in it I would of thought with my limited knowledge that a seal or fault in the servo is causing the leak into the hose!
#6 Shooter63
Shooter63
  • 1,299 posts
Posted 29 October 2019 - 07:33 PM
I may have left out an important piece of info, the car is a 1990 with the master cylinder attached to the servo, so yes it's the master cylinder leaking into the servo.
Shooter
#7 Shooter63
Shooter63
  • 1,299 posts
Posted 29 October 2019 - 07:37 PM
And this is the very sort of info that is making me think of going for a tilton/AP racing type vertical master cylinder with remote fluid tank for my mk1
Shooter
#8 cal844
cal844
  • 9,736 posts
  • Local Club: TFMOC
Posted 29 October 2019 - 09:49 PM
Get a replacement
