Recommended Duplex Gears And Chain
11 replies to this topic
#1 JonnyAlpha
JonnyAlpha
  • 2,749 posts
  • Local Club: Exmoor Minis
Posted 27 October 2019 - 09:46 PM
Hi;
I am building a fast road engine (1310, AC RS Cam, Stage One, Mildly Modified Head).
I don't want to spend extra on a Vernier Duplex Setup but "think" I need a Duplex Chain as they stretch less after fitting and Gear Setup to replace the standard one in this Metro A+ 1275 (Circa 1989). To set it up I was going to use a standard woodruff key and then work out what degree offset key I needed.
The problem is that there are so many gear and chains about I need some help picking the correct one.
http://www.minispare...sic/duplex.aspx
#2 gazza82
gazza82
  • 3,099 posts
  • Local Club: TMF+
Posted 27 October 2019 - 10:56 PM
Use IWIS chain ...
#3 JonnyAlpha
JonnyAlpha
  • 2,749 posts
Posted 28 October 2019 - 08:14 AM
Use IWIS chain ...
On the original gears?
#4 ACDodd
ACDodd
  • Mini Docs
  • 2,836 posts
Posted 28 October 2019 - 12:27 PM
Yes if the gears are in good condition.
Ac
#5 JonnyAlpha
JonnyAlpha
  • 2,749 posts
Posted 28 October 2019 - 07:01 PM
Use IWIS chain ...
Like this one sold by Kieth Calver.
Ac
Ok saves money, I'll check the Timing Gear that I took off. I think it looked fine.
#6 gazza82
gazza82
  • 3,099 posts
  • Local Club: TMF+
Posted 28 October 2019 - 11:52 PM
Got my IWIS chain from Minispares ...
#7 JonnyAlpha
JonnyAlpha
  • 2,749 posts
Posted 29 October 2019 - 06:28 PM
Which one?
I found this one but none are labelled as IWIS
#8 Curley
Curley
  • 471 posts
  • Local Club: Not MINI friendly
Posted 29 October 2019 - 10:16 PM
Use IWIS chain ...
What he said. A standard setup with a modern IWIS chain is all you need.
#9 Zami
Zami
  • 185 posts
Posted 30 October 2019 - 03:44 AM
Which one?
Back in June I asked MS if their chains were IWIS and was told they are not.
#10 Rorf
Rorf
  • 866 posts
Posted 30 October 2019 - 07:52 AM
A standard chain should last 100 000 kms plus comfortably as long as the camshaft lobes are not too vicious, the valve springs not too strong and good engine oil, which is changed regularly, is used.
Of course if you are into racing then it is a totally different ball game :D
#11 bantu
bantu
  • 12 posts
Posted 30 October 2019 - 12:58 PM
Which one?
#12 bantu
bantu
  • 12 posts
Posted 30 October 2019 - 01:00 PM
I bought one of those chains a few months ago from minispares and it was a IWIS chain
