Rad Cap Preference
7 replies to this topic
#1 croc7
croc7
  • 894 posts
Posted 29 October 2019 - 05:52 AM
Street car, 1360, 10.5:1 compression. Currently running a 13# cap. Would the mini cooling system like a 15# rad cap?
#2 unburntfuelinthemorning
  • 2,003 posts
Posted 29 October 2019 - 06:59 AM
As standard, in the British market at least, I believe the 13lb caps were used when a 180oF thermostat was used and a 15lb cap when a 190oF 'stat was used.
#3 mini13
mini13
  • 3,811 posts
Posted 29 October 2019 - 09:13 AM
realistically its not going to gain you anything, all it does is push the boiling point up a few degrees, using an onlin calculateor i get the below results for the boiling points
13lb cap   118deg c
15lb cap   120deg c
#4 nicklouse
  • 19,057 posts
Posted 29 October 2019 - 09:14 AM
only ever used a 13LBs cap. never needed anything else.
#5 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 29 October 2019 - 02:29 PM
What thermostat are you running ?
Is heat a problem?
#6 gazza82
gazza82
  • 3,099 posts
  • Local Club: TMF+
Posted 29 October 2019 - 02:57 PM
One problem is usually the length of the rad cap .. some are shorter and therefore don't seal properly .. meaning you lose your coolant when it heats up.
#7 cooperd70
cooperd70
  • 793 posts
Posted 30 October 2019 - 02:57 PM
Std up to '74 13lb cap and from '74 onwards 15lb cap. Thermostat was 82c up until '76 and 88c after in the UK.
#8 croc7
croc7
  • 894 posts
Posted 31 October 2019 - 07:48 PM
Is heat a problem?
180 degree.  No problem with heat, just curious is all.
