Tappets
6 replies to this topic
#1 dotmatrix
dotmatrix
  • 441 posts
Posted 29 October 2019 - 03:41 PM
I know the story. They have to be round and not flat on the surface or they wont spin round and will wear.
Is this true? Or is it a myth.
Regardless of what cam?
The last set of followers i got from minispares were completely flat
#2 nicklouse
  • 19,066 posts
Posted 29 October 2019 - 03:47 PM
the cam followers are a hollow cylinder with a flat end that is perpendicular to its sides. the cam profile should have a slight angle on the lobes to cause rotation of the followers. (many do not seem to have this).
#3 Rorf
Rorf
  • 866 posts
Posted 29 October 2019 - 05:16 PM
Followers I got from minispares also appeared flat but then they say the radius is 50 inches - might not be noticeable to the human eye.
#4 dotmatrix
dotmatrix
  • 441 posts
Posted 29 October 2019 - 05:28 PM
I put them on a flat surface like a piece of glass and checke that they topple/wobble a bit from side to side. These didnt
#5 dotmatrix
dotmatrix
  • 441 posts
Posted 29 October 2019 - 05:32 PM
Yes the cam lobe top should also have a bit of an angle to it. I have also heard this.
#6 Spider
  • 15,870 posts
Posted 29 October 2019 - 05:44 PM
Yes, they should have a radius on the face of them, typically ground on a 38 to 48" radius. An assembly check is to put them on a True Flat Surface and you should be able to just get a 0.001" Feeler under the 'high' side when tipped / rocked.
#7 dotmatrix
dotmatrix
  • 441 posts
Posted 29 October 2019 - 06:07 PM
Thank you. It will be interesting to see how long the camshaft lasts in this engine then. It was a used austin metro cam. The ~62hp one.
