92 Cooper S Conversion
2 replies to this topic
#1 Emlyn32
Emlyn32
    Starting My Mini Up
  • 1 posts
Posted 29 October 2019 - 04:29 PM
Revs fully when cold n when warm splutters any ideas?
#2 Fast Ivan
Fast Ivan
  • 2,911 posts
Posted 29 October 2019 - 05:33 PM
Would that be a carb or injection model?
#3 cal844
cal844
  • 9,734 posts
  • Local Club: TFMOC
Posted 29 October 2019 - 05:37 PM
Sounds lean, however before touching the carb, I'd recommend a good service of the ignition system if not done recently. To save money if you're a member of an owners club you can try asking if someone can bring a car to you, so you can try parts on yours... change one part, run the car... if no improvement revert back or change the next part in the chain.. always make sure you test drive the same route after changing each part...
