I built a Speeduino last year, really just as a comparison to the Megasquirt-2 that I use on my Mini, and potentially to use it instead of a Megasquirt in another ongoing project.
The only difference you will see in TunerStudio (apart from the "ini" file title) is the indicators available at the bottom of the screen and potentially the menu layout at the top - but the menu layout varies within the megasquirt ranges anyway depending on which version of the firmware you are using.
But when you select the ignition advance table, it's just a table irrespective of hardware or firmware.
As already mentioned the "standard" Speeduino only has logic level spark outputs so you would either need a separate 2 channel ignition amplifier to run the old Ford EDIS wasted spark coilpack, or a logic level wasted spark coilpack, or a logic level normal coilpack (4 built-in coils) or logic level COP/CNP. The 4 coil coilpacks or COP/CNP would require a cam sensor as anything with 4 coils is, by definition, fully sequential.
I now use the Bosch coilpack, the fairly common one, usually goes under part number 06A905097, but my setup is fully sequential anyway because I run the MS-2 siamese code (which is unique to the MS-2) as I run port injection.
And that's the only reason I wouldn't use the Speeduino on my Mini, it doesn't have any unique code to deal with charge robbing on the injection side of things.
But for ignition only, or for injection on a normal 8 port engine (or wet manifold on an A series and ignore the charge robbing) I would say it's about half way between an MS-2 and an MS-3 and way superior to Megajolt, and probably a lot cheaper, esp. if you build it yourself.
If you are familiar with TunerStudio already, just download the latest Speeduino "ini" file and create yourself a temporary project and have a look.
EDIT - and for the wideband have a look at the 14point7 stuff. The Spartan 2 (or 3) is very popular in the Megasquirt world. Only one supplier in the UK I think (I buy my stuff straight from Alan in Canada). In the early days I tried Innovate (numerous controller failures) then TechEdge (very good but ultimately didn't have one feature I needed) but have found the particular 14point7 modules I use to be very reliable.
Edited by retired, 06 November 2019 - 11:20 AM.
