My Sidewalk Is Cracking Up
2 replies to this topic
#1 minisidewalk
minisidewalk
  • 0 posts
Posted 03 November 2019 - 08:15 PM
Is this any thing to worry about on my rover mini sidewalk 1995,it’s like this on both sides?Attached File  9D94C61F-1B1E-4FE9-869A-904EF6BFED6D.jpeg   74.6K   4 downloads
#2 bpirie1000
bpirie1000
  • Area Managers
  • 2,567 posts
  • Local Club: Amoc
Posted 04 November 2019 - 12:01 PM
Could be a split in the paint or could,be slot deeper.
Sand it down is the only way to find out.
#3 Tupers
Tupers
  • 4,176 posts
Posted 04 November 2019 - 12:43 PM
That looks like cracking caused by running for too long on worn out from subframe mounts.
I would check the other side as well. Although it’s not terminal you should definitely have your subframe mounts checked/replaced and have any cracks cleaned up, drilled at the ends & welded up.
