Oh really? Thank god was worried it was going to need the head taking off, ah okay I might have to see if anyone local has a spare dizzy I can borrow to test, the fuel pump is about 3-4 years old but only fitted 18 months ago when I bought the car but I will test to check
compression aint too bad , I removed the module and refitted ,another electronic ignition setup , cant remember which , you running mechanical fuel pump it may be its had its day , take the pipe off the carb and stick it in a jamjar then get someone to crank it over , don't forget to remove the ht lead though or it may fire upReset the spark plugs to 32thou, but more worryingly did a compression test and the results are
C1 - 165psi
C2 - 150psi
C3 - 145psi
C4 - 155Psi
id try a spare dizzy first ,itl probably fire straight up with a replacement dizzy and timing set correctly
I wouldn't just yet, do one small thing at a time, if it doesn't improve reset and move elsewhere
