Starting Issue
#31
Posted 11 November 2019 - 02:46 PM
#32
Posted 11 November 2019 - 02:58 PM
Yes but as has been asked are you getting the right voltage at the engine end...and make sure the battery Clamps are tight
#33
Posted 11 November 2019 - 03:28 PM
There is 12v at the battery end and the battery terminals are tight I am also getting 12v at the coil where else in the engine bay side of electrics do I need to check?
#34
Posted 11 November 2019 - 05:42 PM
Battery terminals are tight
Earths are clean
Over 13ish volts at the battery
Over 13ish volts at the solenoid
Over 13ish volts at the coil
Coil connections tight
Solenoid connections tight
Anything else I’ve missed?
#35
Posted 11 November 2019 - 06:43 PM
Not the battery then.
#36
Posted 12 November 2019 - 04:57 PM
#37
Posted 12 November 2019 - 05:05 PM
You getting a spark from the HT leads? .. start with the main lead from coil to distributor
Edited by gazza82, 12 November 2019 - 05:06 PM.
#38
Posted 12 November 2019 - 06:24 PM
Yes it’s sparking the car runs and drives but struggles to start when cold or left for a few hours
#39
Posted 12 November 2019 - 11:02 PM
In that case is the choke working properly?
#40
Posted 13 November 2019 - 06:26 AM
The cable moves and the jet drops when the choke is pulled, so I assume it is my only thought is would the waxstat cause an issue?
#41
Posted 15 November 2019 - 04:47 PM
#42
Posted 15 November 2019 - 09:43 PM
I'm sorry I don't know what else to suggest. It's not straightforward trying to diagnose these types of problem from a distance. Is there anyone local who could look at it with you?
#43
Posted 15 November 2019 - 10:00 PM
#44
Posted 16 November 2019 - 08:44 AM
I’ll have to ask around unfortunately we are just buying a house so funds are really tight else I would take it down to a garage, think I’ll have to stick her in the garage until I’ve got some money to get her looked at but thanks for the help
#45
Could it be a sticky solenoid?
Possibly might be worth replacing that for a few quid
