Edited by gazza82, 16 November 2019 - 10:06 AM.
Starting Issue
#46
Posted 16 November 2019 - 10:05 AM
#47
Posted 16 November 2019 - 01:47 PM
Just re-read you first post ... you don't clean rotor arms with sandpaper ... you can open up the gap too much .. rub it on the tyre or very, very fine wet&dry. Also some new dizzy parts are poor quality. I know people in my car club where the new rotor arm has fallen apart in the dizzy!
Ah sorry should have clarified with the sandpaper, it was some 1400 grit wet and dry I just ran it over the surface the ones to clean it up a little bit but wasn’t exactly dirty, the rotor arm itself looks ok I’ve always tried to replace parts with the highest quality I can get
#48
Posted 16 November 2019 - 03:55 PM
#49
Posted 17 November 2019 - 10:18 AM
Edited by creakyjaws5533, 17 November 2019 - 10:19 AM.
#50
Posted 17 November 2019 - 10:41 AM
#51
Posted 19 November 2019 - 06:18 PM
#52
Posted 19 November 2019 - 07:15 PM
A few months back my '88 Fiesta was just making a single click when I tried to start it. After charging/changing the battery and pulling the starter, it turned out that the main battery to starter power cable had corroded internally causing resistance. Changed it out for a new one and it started right up.
Might be worth a check with a meter to make sure your cable is still good?
#53
Posted 21 November 2019 - 05:04 PM
#54
Posted 03 December 2019 - 09:09 AM
#55
Posted 03 December 2019 - 10:29 AM
#56
Posted 03 December 2019 - 01:55 PM
Battery down a cell, get it load tested
I don’t think it’s the battery as it has plenty of juice to crank the starter but worth testing how would I load test just a multimeter over the terminals when cranking?
#57
Posted 03 December 2019 - 02:30 PM
I don’t think it’s the battery as it has plenty of juice to crank the starter but worth testing how would I load test just a multimeter over the terminals when cranking?Battery down a cell, get it load tested
You can load it by putting on the lights, then try to start the engine, if they dim or go off completely you have an issue somewhere. (Measure the voltage across the battery)
Then start the engine (if you can) then once settled at idle put the lights on first (check voltage at battery)
Then heater or rear demister (check voltage again) the voltage shouldn't change
Hope this helps
Cal
#58
Posted 03 December 2019 - 05:31 PM
Hope this helps
Cal
So I did the test with lights on as I cranked and they dimmed ever so slightly but I mean hardly anything, then did a check on spark plugs all 4 producing a really healthy spark on all 4 leads, then though I’d do a compression test again for sanity and results are
Cylinder 1 175psi
Cylinder 2 150psi
Cylinder 3 125 psi
Cylinder 4 160 psi
Not sure how cylinder one has gone up that much but looks like the head gasket might have gone again? Would that stop the car starting? The test was done with all 4 plugs out an the throttle open
#59
Posted 03 December 2019 - 06:52 PM
#60
Posted 03 December 2019 - 06:57 PM
The middle 2 compression figures are low which suggests an issue, I dont think that the figures point towards a head gasket issue though, so could be a valve or ring issue?
Ah that’ll be a right pain then, I guess the test for rings is oil in the bore before the compression test? Anyway to test the valves?
