Ah that’ll be a right pain then, I guess the test for rings is oil in the bore before the compression test? Anyway to test the valves?The middle 2 compression figures are low which suggests an issue, I dont think that the figures point towards a head gasket issue though, so could be a valve or ring issue?
Ideally you want to do a dry compression test, then add a little oil to each bore and repeat. You can also get leak down tests which can be a better test
