Best Place To Find Exacton Wheel Nuts
11 replies to this topic
#1 will_nic
will_nic
  • 104 posts
Posted 05 November 2019 - 11:15 AM
I've got a set of Exacton/Mini Special wheels I'm planning to turn into split rims.. Are there any chrome wheel nuts available? I can only seem to find the silver ones which MiniSpares sell.
Thanks,
Will.
#2 petey81
petey81
  • 1,355 posts
Posted 05 November 2019 - 11:22 AM
This is where i bought mine from.
I will try and find the correct page for you.
http://www.rallydesign.co.uk/
#3 will_nic
will_nic
  • 104 posts
Posted 05 November 2019 - 02:21 PM
Thanks!
Are these the ones?
https://www.rallydes...roducts_id=4652
#4 nicklouse
  • 19,067 posts
Posted 05 November 2019 - 02:56 PM
Thanks!
Are these the ones?
did not think the Special wheels had a taper seat. the washer is what hold the wheel in place.
#5 will_nic
will_nic
  • 104 posts
Posted 05 November 2019 - 06:12 PM
Sounds like you're right.. If anyone could point me in the right direction that would be great!
Thanks!
Are these the ones?
#6 will_nic
will_nic
  • 104 posts
Posted 07 November 2019 - 09:39 PM
Anyone know where I might find these wheel nuts please?
#7 Tupers
Tupers
  • 4,176 posts
Posted 08 November 2019 - 01:22 AM
I can only find the silver type that Mini Spares sell.
I’ve found that the plating on every set of chrome wheel nuts I’ve ever installed has began to peel or show rust within 12 months of road use.
If you want a real long term solution for shinny wheel nuts then you need to find somewhere to make you a set in stainless or get some real quality chrome work done. Neither are going to be affordable.
#8 petey81
petey81
  • 1,355 posts
Posted 08 November 2019 - 09:21 AM
Sorry for the late reply. I can't find my invoice but I will call them today.
#9 will_nic
will_nic
  • 104 posts
Posted 12 November 2019 - 11:10 AM
Hi Pete,
I've measured up the wheels I have and these nuts seem to be correct apart from being too long..
https://www.rallydes...roducts_id=4660
Are these what you purchased?
Otherwise I'm tempted to buy a set and machine them down the sleeve in the lathe...
Cheers.
#10 petey81
petey81
  • 1,355 posts
Posted 12 November 2019 - 09:57 PM
Hi.
I didnt have much luck on the phone and trying to find my invoice.
They look to be correct and i do remember cutting down the studs.
#11 will_nic
will_nic
  • 104 posts
Posted 13 November 2019 - 11:01 AM
Thanks heaps anyway Pete!
I'll give them a shot. I don't mind shortening the studs.
Cheers.
Hi.
#12 Artstu
Artstu
  • 837 posts
Posted 13 November 2019 - 05:54 PM
I wonder if these guys would make some to suit based on a similar design https://www.ebay.co....PQAAOSwgQ1cUD-9
