Metro To Mini Timing Chain Cover
8 replies to this topic
#1 JonnyAlpha
JonnyAlpha
  • 2,748 posts
  • Local Club: Exmoor Minis
Posted 10 November 2019 - 06:15 PM
Hi;
I have just been trying out my newly acquired Blast Cabinet. Had a go at the timing chain cover, but noticed a hole in it :-(
Question:
If I replace it with a Mini (No SPI one) like this one here will the timing marks still be in the correct place?
May try and pick up a cheaper second hand one, either Metro or Mini?
#2 nicklouse
  • 18,679 posts
Posted 10 November 2019 - 06:47 PM
Yes. The engines are the same. But your damper may not be correct depending where it actually came from.
#3 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 10 November 2019 - 07:21 PM
By damper, do you mean the crank pulley? I am using the one that came off of the engine?
#4 jaysmini1983
jaysmini1983
  • 217 posts
  • Local Club: West Country Mini's
Posted 11 November 2019 - 12:32 PM
or just weld up and repair the hole.
#5 cal844
cal844
  • 9,638 posts
  • Local Club: TFMOC
Posted 11 November 2019 - 12:59 PM
That can be done, possibly the best way to repair.
#6 Ethel
  • 26,042 posts
Posted 11 November 2019 - 02:40 PM
Looks like they will be, never heard that they're not - you could set it to tdc with the holey cover so you can confirm if you replace it.
I'd go for a repair too, if you don't have access to a welder*, an epoxy patch should do - possibly better as it can cover all the pitting, use  acid to remove every bit of rust to prep.
*it's a small enough bit to tout around some back street garages with some beer tokens in your pocket.
#7 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 11 November 2019 - 04:59 PM
I am pretty dab at welding up small repairs such as this but I don’t have any gas at the mo. As well as the repair I have also been advised that I should flatten down the breather somewhat as it’s from a Metro (so is the engine) and on a Mini there is not a lot of room between the breather and the radiator?
#8 GraemeC
GraemeC
  • 7,440 posts
Posted 11 November 2019 - 06:13 PM
Between breather and fan
#9 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 11 November 2019 - 07:55 PM
Oh yes - sorry :-)
