Hi all, I am a fairly competent mini enthusiast, however I am stumped on this one, and hoping for help.
Stats
1979
1.1A series
Clubman
I have taken the 1.5 inch carb off to sort a fuel leak that was picked up at its mot and failed because of it.
I took the carb off and gave it a clean. I didnt strip anything from it. Just tried to see if the leak was coming from the jet area. I gave it an external clean and put it back on the car to see if I could see more clearly where the leak may be coming from.
But now it wont start. The spark plugs are wet with fuel and every spark plug sparks after I took each one out to check.
The engine now turns over but does not fire. I haven't touched the distributor or anything. I'm very confused.
Help needed! Pleeease.
Turn Over But No Ignition
foggy
, Nov 10 2019 08:09 PM
No replies to this topic
This topic is locked
