You'll end up getting beached
I think raising the ride hight a little would be the way to go or see if you can tuck the exhaust up a little higher
Haha ok. I think since it's supposed to be easy to change the ride height with hi-lo's I could probably set it to as high as possible until I finish college next June. Then I can just set it to a bit more normal height once I've finished and don't have to go over that speed bump anymore.
Not sure how I'd tuck the exhaust up any higher. Is there usually a little extra room where moving the bracket/fabricating a new one could improve clearance?
