I don`t think 0.002" on a surface grinder is going to make any negligible difference to the CR at the expense of the head gasket integrity.
Its just good practice to ensure the build is the very best it can be.
Posted 17 November 2019 - 10:34 AM
Posted 20 November 2019 - 07:18 AM
Check using both sides of the ruler.
0.001" is the outside limit over the length of the block and 0.0004" (4 tenths of 1 thousands) over the width.
Posted 20 November 2019 - 08:32 AM
Bummer mate.
As another check, but won't say how far it's out, you can rub a Shapening Stone over it, just 3 - 5 wipes will be well enough. This will show the high spots.
No disrespect to what you've found here, but it's a lot of work to go to. If it needs skimming, then it needs it, but can I suggest having another set of eyes check it first.
