Rear Beam Conversion
Posted 14 November 2019 - 02:12 PM
Posted 14 November 2019 - 02:17 PM
if you are talking about one of the kits sold by most of the retailers then it is a subframe replacement kit that reduces weight and changes the rising rate spring to a linear coil spring which then limits the use of the car.
so the suspension stays as a fully independent trailing arm set up.
Posted 14 November 2019 - 03:21 PM
As Nick says.. don't confuse with an Anti Roll bar, which limits the independent suspension possibilities.. I always think a beam is not a good idea on a road car... severely weakens a rear end impact... in a race car this is mitigated usually by turretted suspension feeding straight into the roll cage rear arms which are extended into the boot area
Posted 14 November 2019 - 03:40 PM
Posted 14 November 2019 - 05:48 PM
I find this name these days a misnomer for the kits that are commonly available.
They do away with the rear subframe, which, as a bare item, really isn't that heavy, but adds a fair bit of strength and rigidity to the car.
All the ones I've seen also do away with the rubber cones and you're forced to use Coil Overs. I think this a backward step for a car for road use.
I guess one advantage is they do away with the rust trap that the stock rear subframe is.
A Beam Axle, which once was available for a Mini, is just that, a Beam Axle very similar to a Trailer. They were widely used for Track work and very effective as regardless of what roll position the body took up, the rear wheels were always square to the road. While these were quite advantageous on the track, you wouldn't run one on the road.
Posted 14 November 2019 - 06:41 PM
Allspeed used to make them. My Micra has one as standard.
Is Dural-beam the right description for the ones that use the Mini radius arms?
Posted 14 November 2019 - 07:39 PM
nope it was just the "Brand" of aluminium used for making the Alloy ones and the early Alloy sump guards.
Posted 14 November 2019 - 07:43 PM
Autocar called it a Dural beam when talking about the one on the back of the Midas.
Posted 14 November 2019 - 08:04 PM
Posted 14 November 2019 - 08:13 PM
Dural is just a conjunction of durable and aluminium.
Thanks, sadly not something that could be said of the thin steel Midas item.
