T’Stat Gasket
Posted 15 November 2019 - 07:14 AM
Posted 15 November 2019 - 07:24 AM
Cork every time. I buy small sheets of 1.5 mm auto gasket cork, cut one out and use it without sealant, as the sealant inhibits the cork from swelling and giving it a tight seal. Never had one leak yet.
Posted 15 November 2019 - 08:30 AM
I used to use the cork ones dry that Unipart supplied without trouble, lately I've been using Minispares paper gaskets with sealant. I think the cork ones were better.
Posted 15 November 2019 - 10:09 AM
Cork or paper. Needs to be of a good thickness.
No sealant, just a smear of grease on each surface.
Posted 15 November 2019 - 10:23 AM
Posted 16 November 2019 - 05:35 AM
Posted 16 November 2019 - 05:44 AM
I hope you mean 50 inch pounds!
I like the blue cardboard ones from MiniSpares, I use them dry.
Posted 17 November 2019 - 06:11 AM
Oops! Yeah it was "/#, big fingers. Never had much luck with paper gaskets-what would be the torque? Just snug enough not to leak? What is the purpose of a smear of grease on the gaskets?
Edited by croc7, 21 November 2019 - 02:08 AM.
Posted 17 November 2019 - 08:14 AM
Posted 19 November 2019 - 06:37 PM
Posted 19 November 2019 - 06:48 PM
As long as the head gasket is good then you shouldn't have problems with the thermostat gasket
