Float Bowl Lid Needle Valve Thing Getting Stuck Regularly
7 replies to this topic
#1 Vinay-RS
Vinay-RS
  • 2,093 posts
Posted 15 November 2019 - 08:10 AM
Hi everyone,
I am currently having an issue where one of the two needle valve things keep getting stuck. I have taken them both out, cleaned them with some thinners, wiped them down and refitted them. I have done this a few times and it still keeps happening. I was wondering what else might be causing the one valve to get stuck? The result is that one float bowl empties and then the car misfires.
Regards,
Vinay
#2 nicklouse
  • 17,945 posts
Posted 15 November 2019 - 08:18 AM
crud in the tank/fuel system.  which carb as you look from the front. left or right? which carb gets feed first?
fit an inline filter.
change valves and seats.
#3 Vinay-RS
Vinay-RS
  • 2,093 posts
Posted 15 November 2019 - 01:25 PM
from the front, it's the right hand carb.
There is an inline filter under the tank at the back of the car.
Change the two needle valves and seats?
#4 cal844
cal844
  • 9,488 posts
  • Local Club: TFMOC
Posted 15 November 2019 - 01:35 PM
Make sure the filter is clean and then change the needle valves and seats
#5 nicklouse
  • 17,945 posts
Posted 15 November 2019 - 01:52 PM
so it is the carb that gets the dirty fuel first.
I would consider renovating the fuel delivery system.
replace all pipes and hoses and clean the tank out. and replace the filter.
#6 luismx123
luismx123
  • 525 posts
Posted 15 November 2019 - 01:56 PM
had the same. Bought the "uprated" minispares ball valve version which didnt work that well so I went for the VITON Tipped needle valve set - theyre the black tipped ones you see. this solved my problems...
#7 Vinay-RS
Vinay-RS
  • 2,093 posts
Posted 15 November 2019 - 02:31 PM
I don't know which ones are in these carbs... They came with the SU rebuild kit. Maybe they are the bad ones :(
Thanks! That might be the only option that remains now. Change all the flexible lines and have the tank chemically cleaned. It seems extreme but possibly the only option now :(
#8 nicklouse
  • 17,945 posts
Posted 15 November 2019 - 03:15 PM
don't forget the hard lines as well.
