Subframe Differences
8 replies to this topic
#1 wreckitralph
wreckitralph
  • 180 posts
Posted 18 November 2019 - 06:11 PM
   looking at getting a subframe and  it appears they are different  from 91 onwards the car is earlier than 91 but with the floor and heelboard i have fitted  being  of a later type       what are the main differences   are the main mounting points the same dimenions regards boot floor and heel    ime not running  fuel injection its carbs for me  so what are the differences between pre 91 and 91 on rear subframes
Edited by wreckitralph, 18 November 2019 - 06:39 PM.
#2 cal844
cal844
  • 9,734 posts
  • Local Club: TFMOC
Posted 18 November 2019 - 06:16 PM
The only differences are
Front::
Engine is 1/2 inch forward in the frame.
MPI had the front mount radiator
Rear::
Exhaust hangers and associated welding
MPI had additional strength overall
Edited by cal844, 18 November 2019 - 06:17 PM.
#3 wreckitralph
wreckitralph
  • 180 posts
Posted 18 November 2019 - 08:37 PM
thats grand thank you  as long as the main mounting points are in the same area thats all that matters  thanks forn the input mate
#4 cal844
cal844
  • 9,734 posts
  • Local Club: TFMOC
Posted 18 November 2019 - 10:13 PM
Yes the body mountings are the same as the rest of the rubber mounted subframes
Happy to help, just post as needed ?
Cal
#5 surfblue
surfblue
  • 1,829 posts
Posted 19 November 2019 - 07:17 AM
Cant imagine why changes made to subframes in '91, surely all still on carbs at that time? and the MPI front mounted radiator was still 5 years away?
#6 wreckitralph
wreckitralph
  • 180 posts
Posted 19 November 2019 - 11:45 AM
i have no idea i was looking at a new subframe not even thinkining  that it would be different  through the years except for possibly a bracket or  something like that  but going from the  listings their different
#7 mab01uk
mab01uk
  • 13,075 posts
Posted 19 November 2019 - 12:32 PM
As said the rear subframe exhaust mountings are different on the later versions from 1991 carb or injection, ie. shaped rods are welded to the frame to hang modern style rubber exhaust hangers from. You could fit the later subframe to an earlier car (all mountings to bodyshell are the same) but would have to fit later type exhaust box or adapt existing.
REAR SUBFRAME 1991on WITH LATE EXHAUST HANGERS
"metal prongs/hangers for rubber strap type mounts as fitted from 1990 cars."
http://www.minispare...c/MS45LATE.aspx
Edited by mab01uk, 19 November 2019 - 12:38 PM.
#8 Ethel
  • 26,802 posts
Posted 19 November 2019 - 12:51 PM
Foresight? (Ok, unlikely it was Rover)
Hif Carb perhaps?
#9 nicklouse
  • 19,063 posts
Posted 19 November 2019 - 01:40 PM
Hif Carb perhaps?
change from HS to HIF carbs moved the engine forward.
