Flywheel Housing Fit
1 reply to this topic
#1 viz139
viz139
  • 727 posts
  • Local Club: Irish Mini Owners Club
Posted 19 November 2019 - 11:50 PM
Apart from the differences between A and A+ idle bearings and the holes for breathers and crank sensor should all housings fit all engines with regard to stud, bolt and dowel holes lining up. We are trying to fit a DAM 6259 (998 A+) in place of a damaged TRD 10015 ('94 1275 CARB).
We don't need the crank sensor and we have drilled and taped the breather holes.
We are trying to measure the idle gear thrust washer gap by mating the housing to the gearbox only but the top dowel appears to be misaligned  and maybe distorting the housing so that the idle gear locks up. We have tried two housings with the same result.
#2 nicklouse
  • 19,063 posts
Posted 19 November 2019 - 11:52 PM
All the same fitting.
