Crankshaft Pulley
3 replies to this topic
#1 cristiano1968
cristiano1968
  • 444 posts
Posted 20 November 2019 - 11:25 AM
I'm sorting my engine out
Timing gears etc
My question is does the crankshaft pulley wear out or can I still use mine.
it's a 998cc engine 1989
#2 nicklouse
  • 19,060 posts
Posted 20 November 2019 - 12:08 PM
inspect it  especially around the key way and on the sealing surface. and if it has a damper part check the rubber condition and the timing mark alignment.
#3 Spider
  • 15,859 posts
Posted 20 November 2019 - 04:41 PM
Also check the V section in it. These do wear if it was run with a poorly adjusted or worn belt.
Check that the faces of the V are flat and offer a new belt up to it but bend it back so you can check that it's not bottoming out in the V as well. You want to see at least a 2 mm gap here and preferably 3mm or more.
#4 cristiano1968
cristiano1968
  • 444 posts
Posted 20 November 2019 - 04:58 PM
Ok ?
