Uprated Main Studs/bolt Kit For A 998?
7 replies to this topic
#1 The_R1_Kid
The_R1_Kid
  • 11 posts
Posted 20 November 2019 - 11:32 PM
Hello I've been trying to tack down an uprated Main bearing Stud or bolt kit for my 998cc with 1.75inch main journals
Found this below but it is no longer available. Others have sold the kit but they are the ones that supplied it. Unless there is stock laying around somewhere its not an option
http://aptfast.com/s... Main Stud Kit
Do I have any options or am I only to use normal new Main bolts? I would like to have a worry free overbuilt bottom end if possible, short of adding a center strap. Using the best bolts possible would be prudent if possible.
Thanks,
Kyle
Edited by The_R1_Kid, 21 November 2019 - 12:30 AM.
#2 unburntfuelinthemorning
  • 2,003 posts
Posted 21 November 2019 - 07:04 AM
The main bearing bolts aren't normally a problem and don't need uprating,  use ARP for the big end bolts though.
#3 Spider
  • 15,859 posts
Posted 21 November 2019 - 07:55 AM
This ^.
I also wouldn't be fitting a Centre Main Strap. Regardless of what mods have been done, you just won't need one. The fitting of most entails removing material from the Cap and this only weakens them.
#4 The_R1_Kid
The_R1_Kid
  • 11 posts
Posted 21 November 2019 - 08:30 AM
Okay Thank you Gents ill drop the search and use normal main bolts. I did acquire the ARP rod big end bolts.
3rd paragraph does say to use ARP washers under the main bolts. Thoughts?
https://www.calverst...ain-cap-issues/
#5 Spider
  • 15,859 posts
Posted 21 November 2019 - 09:07 AM
What is the Engine, what modifications are contemplated and what is it to be used for ?
#6 The_R1_Kid
The_R1_Kid
  • 11 posts
Posted 21 November 2019 - 05:43 PM
998cc +.020
10.5:1 compression ratio
12G295 head
1.21 in 1.0 exhaust valve double valve springs
Md266 cam kent
1.3:1 Alloy Roller Rockers
ARP head studs
Lightened Duplex timing set
Pre balanced Crank damper
Light weight 9.88lbs flywheel
Center oil pickup tube
3.21:1 final drive
Cross pin Diff
70amp alternator
Electronic distributor for the 266 cam
twin 1 1/4" SU carbs HS2
Stub stack
Freeflow manifold
Rc40 exhaust
This is a road car that will be driven hard, revved hard, and one that I want to build once and last a very long time. It's a full nut and bolt stripped chassis restoration/customization Mk4 with a lot of mk1 style.
Measuring the stock main bearing bolt seeing as replacement OEM bolts are not available anywhere either it seems, I found this bolt at ARP that matches the stock mains bolts but are guaranteed to be quality.
https://arp-bolts.co...p?RecordID=3447
along with ARP washers reccomended by Calver tuning
https://arp-bolts.co...hp?RecordID=905
Edited by The_R1_Kid, 21 November 2019 - 05:44 PM.
#7 Spider
  • 15,859 posts
Posted 22 November 2019 - 04:33 AM
OK thanks for the Engine Spec.
Those are the bolts you can use.
Be sure to use new Dowels with them.
You can use Washers if you want, but really, they are not warranted on this build. Be sure however, as with any build, that the Spot Facings on the Caps are free for wear from the old bolts.
#8 The_R1_Kid
The_R1_Kid
  • 11 posts
Posted 22 November 2019 - 11:58 PM
Thanks for the input. Ordered from ARP $24.21 total plus shipping. Cheaper than ordering the potentially Cheeseium OEM bolts from mini spares that are out of stock anyway
