No, just no.
Yes i will try this first.I would see if you can slip the fingers around with a drift and a hammer. They may have slipped.
its been a while since i removed my clutch, and i cant think how it all goes together, if you undid the clucth cover bolts(removeing the pressure) then you would be able to spin the clucth plate, re align and tighten up to then be able to pull the flywheel.
Never Had This Problem Before
dotmatrix
, Nov 21 2019 10:20 PM
16 replies to this topic
#16
Posted 23 November 2019 - 07:48 AM
#17
Posted 23 November 2019 - 07:56 AM
No, just no.its been a while since i removed my clutch, and i cant think how it all goes together, if you undid the clucth cover bolts(removeing the pressure) then you would be able to spin the clucth plate, re align and tighten up to then be able to pull the flywheel.
No indeed. I ended up cutting the rivets off
