Maniflow - Cooper Freeflow Or Lcb
5 replies to this topic
#1 Decsta
Decsta
  • 25 posts
Posted 24 November 2019 - 10:16 AM
Hi Team
I know it's been asked a million times, but reading through all the forums, I still can't quite determine what the correct set up should be.
Engine - 1310, MED Head, Swiftune SW5 CAM, SC Gearbox.. running 90 ish at wheels..
Exhaust set up.. what should I be installing? I have a Maniflow bargain from this very forum fitted currently, but I also ran the same exhaust on my standard 998..!
Manifold first - should I be installing an LCB? Does Stainless make a difference? Road or race?
Exhaust itself, clearly noise isn't an issue - have twin box side exit mild steel Maniflow currently - would a Stainless single box be noticably different / worth the investment?
Alternatively, any recent experiences with RCM? Worth it on a road car that I probably drive 5 times a year??
Thanks in advance,
Dec
#2 nicklouse
  • 19,066 posts
Posted 24 November 2019 - 10:58 AM
All depends on the diameter of the tubes.
but on a big bore an LCB is preferable.
exhaust sounds about right.
#3 johnR
johnR
  • 2,323 posts
Posted 24 November 2019 - 12:29 PM
Maniflow Stage 2 LCB?
#4 croc7
croc7
  • 895 posts
Posted 24 November 2019 - 10:50 PM
I have the LCB / RCM on the car-like the sound and slight performance increase. 1360 with the usual improvements.
#5 ads7
ads7
  • 351 posts
Posted 25 November 2019 - 12:01 AM
Maniflow is a great sounding exhaust, although I'm shortly about to remove the single box stainless 2" bore system complete with medium bore LCB which I won't want much money for - I need a maniflow freeflow manifold and smaller diameter system.
#6 andyapanel
andyapanel
  • 651 posts
Posted 25 November 2019 - 04:02 PM
I fitted a stainless Maniflow single box system to my RSP a few months ago. I also fitted a Cooper Freeflow in Stainless. I nearly bought the LCB, but reading Calver, it seemed better to fit the Freeflow. I bought the stainless version because I was fed up with the standard ones rotting out every few years. Anyway, it is a very good system and the car seems torquier than before. It all fitted together perfectly, thought the rear hanger arrangement is a bit odd IMO.
I have an RC40 in stainless on my 998, and it is a good system, but not quite as well made as Maniflow
If you have 50% more power than my car, I think the advice would be to go for the LCB, but read what Mr Calver has to say.
Don't forget to fit the correct diameter system.
Noise? I was warned by local mini man that the stainless manifold was noisy, but I have not noticed it; mind you, Minis do Noise and Rattles so well, if it was an Olympic event, I am sure they would win every time.
Fit Maniflow and enjoy.
