Lower Engine Steady
4 replies to this topic
#1 sparkymae
sparkymae
  • 141 posts
  • Local Club: None
Posted 25 November 2019 - 04:47 PM
I have a 1990 998cc Mini  RHD with 2 engine steadies left and right that bolt to the rear of the sub frame and one topside on the right, engine to bulkhead. I have done a little research and what i have found out is that in 1990 they repositioned the engine a little bit and installed a forward mounted steady on the sub frame.  It looks like at one time my car had this. Should i put it back to stock or is what i have on my Mini ok? Thanks guys.       Gary
#2 nicklouse
  • 19,055 posts
Posted 25 November 2019 - 05:25 PM
What you have is fine.
#3 mini13
mini13
  • 3,811 posts
Posted 26 November 2019 - 12:52 PM
As above,
these sound like the aftermarket kits below have been added in place of the usual bottom one ( which can break away from the subrframe)
If you need to replace any of the bushes I would advise the MPI ones, as they last much better, to fit them in the bottom stabilizers you will need to drill the hole out bigger though.
#4 sparkymae
sparkymae
  • 141 posts
  • Local Club: None
Posted 26 November 2019 - 05:25 PM
Thank you all very much. Wanted to make sure. :D
#5 nicklouse
  • 19,055 posts
Posted 26 November 2019 - 05:46 PM
The rears were standard and earlier than the front one that, as above broke things.
if they are there keep them.
