Electronic Indicator Relay
6 replies to this topic
#1 maccers
maccers
  • 1,882 posts
  • Local Club: LSMOC
Posted 25 November 2019 - 08:57 PM
I have had one fitted for a few years, was working fine. Now when indicating left it does not work. Indicating Right works fine. Hazard switch and relay is also fine. Lamps are all ok too.
Is it likely the relay, given one direction works fine?
#2 maccers
maccers
  • 1,882 posts
  • Local Club: LSMOC
Posted 25 November 2019 - 08:59 PM
Meant to add, I have tested with a lamp connected to earth, when indicating left the test lamp flashes faster than when indicating right.
#3 cal844
cal844
  • 9,736 posts
  • Local Club: TFMOC
Posted 25 November 2019 - 10:25 PM
The test light might not be enough load to flash at the correct speed.
Check the earths on the indicator units, I'd put my money on the front one being crusty, also make sure the bullet terminal and body end of the earth is clean too
Edited by cal844, 25 November 2019 - 10:26 PM.
#4 Ethel
  • 26,814 posts
Posted 26 November 2019 - 02:13 AM
If one side lights with the hazards, but not as indicators, I'd strongly suspect the indicator  stalk.
#5 maccers
maccers
  • 1,882 posts
  • Local Club: LSMOC
Posted 26 November 2019 - 07:43 AM
Cheers for the feedback. So yes all lights work fine on the hazards, so I know the bulbs and wiring to the lamps are good.
Its just indicating in one direction (left) that they dont work - the relay does click though and like I say the test lamp flashes faster than when indicating right.
I'll take a look at the stalk next - give the contacts a clean up.
#6 maccers
maccers
  • 1,882 posts
  • Local Club: LSMOC
Posted 26 November 2019 - 10:23 PM
Took the stalk off, contacts and a ball bearing rattling around! Might be the problem!!
#7 whistler
whistler
  • 1,898 posts
Posted 27 November 2019 - 10:17 AM
Check out the wiring connectors on the loom behind the carb. Think that's where the left indicator wiring is.
