Dash Refit
14 replies to this topic
#1 Rallye67
Rallye67
  • 46 posts
Posted 26 November 2019 - 04:36 PM
hi  just refitting  dash & the glovebox compartment seems to be hitting the windscreen vent hose , that am I doing wrong ? its a new dash old glove box so dont see whats wrong
help please  O_O
Edited by Rallye67, 26 November 2019 - 06:33 PM.
#2 cal844
cal844
  • 9,736 posts
  • Local Club: TFMOC
Posted 26 November 2019 - 04:45 PM
Try turning the vent so it angles towards the bulkhead more
#3 Rallye67
Rallye67
  • 46 posts
Posted 26 November 2019 - 05:21 PM
i have turned it round already  , seems miles off
#4 Squipper
Squipper
  • 71 posts
Posted 26 November 2019 - 05:42 PM
Is your glove box on upside down :gimme:
#5 Rallye67
Rallye67
  • 46 posts
Posted 26 November 2019 - 05:55 PM
cant be as the cut out for the catch is at the top  =]
#6 RedRuby
RedRuby
  • 1,201 posts
  • Local Club: No
Posted 26 November 2019 - 07:16 PM
In your 4th picture you can see a “tab” at either side of the demister vent, holding the insulation in place, you could try securing a cable tie to them to pull the demister vent towards the bulkhead. I had to do this when I fitted a later heater with slightly larger demister tubing to an older model.
#7 MikeRotherham
MikeRotherham
  • 1,032 posts
Posted 26 November 2019 - 07:40 PM
Is the dash and glovebox a genuine version or an aftermarket?
I have a walnut dash that was original but the glove box is the old cardboard type. The slope at the back is more pronounced than the plastic version you have and even with mine it is a snug fit up against the windscreen vent and pipe.
I got this image from ebay a while ago the glovebox looks slightly different to yours. Is that the problem?
Edited by MikeRotherham, 26 November 2019 - 07:56 PM.
#8 Rallye67
Rallye67
  • 46 posts
Posted 26 November 2019 - 07:49 PM
dash is a new one , everything else including glove box has been swopped  over from old dash so nothing really has changed
#9 MikeRotherham
MikeRotherham
  • 1,032 posts
Posted 26 November 2019 - 08:05 PM
Perhaps the new dash holds the glovebox in a slightly different position to the old one. Can you compare the two together?
#10 MikeRotherham
MikeRotherham
  • 1,032 posts
Posted 26 November 2019 - 08:09 PM
Your pictures don't show the top dash rail.
Are you fitting the dash with that missing?
#11 Rallye67
Rallye67
  • 46 posts
Posted 27 November 2019 - 06:47 AM
should the top rail go in first
#12 MikeRotherham
MikeRotherham
  • 1,032 posts
Posted 27 November 2019 - 06:51 AM
Yes, the bolts are only accessible from underneath the top metal dash rail.
#13 MikeRotherham
MikeRotherham
  • 1,032 posts
Posted 28 November 2019 - 06:57 AM
Rally67 did you sort this?
Does it look ok now?
#14 Rallye67
Rallye67
  • 46 posts
Posted 28 November 2019 - 09:44 AM
havnt had time to sort this yet >_<
#15 Jonesy77
Jonesy77
  • 67 posts
Posted 03 April 2020 - 02:53 AM
Did you get it sorted?
