Which Rear Cylinders To Go With 1275Gt Master And 4 Pots
5 replies to this topic
#1 NDT
NDT
  • 190 posts
Posted 28 November 2019 - 05:29 PM
Hi all
I’m going to be fitting a 1275GT master cylinder plus mini spares alloy four pots.
Anyone know what size rear brake cylinders I should use?
Nick
#2 Spider
  • 15,871 posts
Posted 28 November 2019 - 06:18 PM
The 5/8" Cylinders would be fine.
It might be also worth trying the 11/16" Cylinders if you want to try to get the best from the Rear, but it's likely getting academic.
#3 carbon
carbon
  • 2,590 posts
Posted 30 November 2019 - 07:25 PM
Nick,
Are you using a pressure limiting valve for the rear brakes?
#4 Chris1275gt
Chris1275gt
  • 1,053 posts
Posted 30 November 2019 - 07:59 PM
Is it a single line brake system.
#5 NDT
NDT
  • 190 posts
Posted 04 December 2019 - 09:42 AM
Morning all, thanks for the help so far!
I will be using an adjustable pressure limiting valve to the rear.
It is a single line system.
Nick
#6 nicklouse
  • 19,066 posts
Posted 04 December 2019 - 09:46 AM
Nick
if adjustable then it does not really matter what you fit.
if original then I would do as Moke says.
