Sudden 'dead' Motor
5 replies to this topic
#1 Eddie B
Eddie B
    Just On Tickover
  • Just Joined
  • 9 posts
Posted 29 November 2019 - 10:38 AM
Only had my mini a few days and not familiar with it just yet. Last night the engine died as I was accelerating in 3rd gear. I managed to turn into a bus layby - tried the starter but all that happens then and since is a clicking solenoid. I called the AA. The patrolman tried to bump start the van by towing it but despite the motor turning it wouldn't fire up. I was towed home and the van is in my garage. So far I have established that there is 13.5 volts reaching the solenoid.
Where do I start?
The vehicle is a 1979 van with a 1275 engine fitted.
#2 gazza82
gazza82
  • 3,099 posts
  • Local Club: TMF+
Posted 29 November 2019 - 12:42 PM
So is the starter turning the engine over? If yes, then you can probably discount the starter and solenoid.
So then it's either fuel or ignition (coil/distributor) .. you have got fuel? ;-)
Did it splutter to a stop? That is probably fuel.
If it was a sudden stop then I'd start with ignition circuit.
Spin the engine and then take a plug out .. wet and petrol smell? Fueling is OK. Plugs dry? Pump or fuel blockage.
There will be posts on here about "Trouble-shooting" ..
If you do change something ... do one thing at a time!
Edited by gazza82, 29 November 2019 - 12:44 PM.
#3 Eddie B
Eddie B
    Just On Tickover
  • Just Joined
  • 9 posts
Posted 29 November 2019 - 01:07 PM
I did manage to find a broken tag on the starter and now that seems to be ok.
The car cut out - didn't splutter so I'll work on the basis that it is an ignition issue.
#4 mini13
mini13
  • 3,811 posts
Posted 29 November 2019 - 01:15 PM
check for a spark? if no spark is there 12v getting to the + side of the coil
#5 Eddie B
Eddie B
    Just On Tickover
  • Just Joined
  • 9 posts
Posted 29 November 2019 - 04:16 PM
Oh the shame of it dear Forum readers. As suggested above I turned the motor over a few times then took out a plug and had a look and a sniff - no hint of fuel! Not a whiff!
I knew I shouldn't have trusted the fuel gauge and meant to nip into Morrisons last night even though it was still reading three quarters full. It conked out about a mile later.
So, I dipped the tank with a stick - nothing, bone dry - so to further check I disconnected what I assume to be the supply to the carb - the other end of it is attached to a fuel filter - put the supply end in a bottle and spun the motor a few more times - nothing - not a drop in the bottle. So thanks gazza for your plug tip.
I suspect I'll be availing myself quite a lot over the next weeks and months whilst I learn more about the foibles of mini ownership
#6 gazza82
gazza82
  • 3,099 posts
  • Local Club: TMF+
Posted 29 November 2019 - 05:07 PM
Well at least it was simple this time .. :-)
The best one I had was the thin wire in the distributor .. that decided that it had run its course on a blind bend, going up hill on a narrow road with a bank on the near side!!
At least it gave me a chance to use my shiny new emergency triangle my parent's bought me the Christmas before .. and which I nearly forgot to go back and get when I managed to bodge the car to get it going again .. and I don't think I've used since!!
