Which Timing Light - Standard Or One With Advance
9 replies to this topic
#1 JonnyAlpha
JonnyAlpha
  • 2,749 posts
  • Local Club: Exmoor Minis
Posted 30 November 2019 - 08:43 PM
I will need a Timing Light gun to help setup my 1310 once it’s been built. Looking at several there are some with a dial and advance timing function.
Question is which one should I get.
Daughter keeps asking me what I want for Christmas ?
#2 GraemeC
GraemeC
  • 7,473 posts
Posted 30 November 2019 - 09:26 PM
I much prefer one with advance
#3 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,078 posts
Posted 30 November 2019 - 09:28 PM
I've got this one, https://www.ebay.co....QgAAOSwjXNbO2oM. I had a couple of other accuspark 'normal' ones which weren't that good but this one I've had no problems with and the timing matched up with AC Dodd's Snap on when he tuned my engine.
#4 smurfomatic
smurfomatic
  • 477 posts
Posted 30 November 2019 - 09:44 PM
I have the same timing light as Alex-95, works very well
#5 dotmatrix
dotmatrix
  • 441 posts
Posted 30 November 2019 - 10:13 PM
if you're only going to be adjusting the timing ad about idle as the manual you can make due with the slightly cheaper non adjustable one, but if you need to do any adjustments or measurements that is not the standard one, you need the adjustable one in my opinion.
Edited by dotmatrix, 30 November 2019 - 10:13 PM.
#6 timmy850
timmy850
  • 3,607 posts
  • Local Club: MITG
Posted 30 November 2019 - 11:14 PM
The one with dialback advance has the advantage that you only need one mark for TDC. You can use the dialback feature to set the advance and also check it over the advance/rpm curve
#7 BaronVonchesto
BaronVonchesto
  • 531 posts
Posted 01 December 2019 - 02:53 PM
i use a standard light but Ive used paint to mark +20 deg on my pully so i can adjust for the 400rpm advance using the teeth.
#8 1314cc
1314cc
  • 306 posts
  • Local Club: tumbleweedminisbristol
Posted 01 December 2019 - 06:21 PM
My first timing gun bought only a couple of months ago with the advance dial.
It was the first time I've set timing ( fitted a new electronic distributor)
and found it really easy to use. If like me and you're new to it ,then I'd go for the advance feature
#9 nicklouse
  • 19,062 posts
Posted 01 December 2019 - 06:27 PM
I would not bother with a none adjustable one.
#10 Dusky
Dusky
  • 5,322 posts
Posted 03 December 2019 - 07:04 PM
Just use timing tape. A lot easier to use imho.
