Cylinder Head Question
11 replies to this topic
#1 plumbo1
plumbo1
  • 13 posts
Posted 02 December 2019 - 07:08 PM
Hi all, I need some help (again) I have a 1974 mk3 1000 that was a complete rust bucket nearly done bodywork floor boot roof etc  I've now taken engine apart and found no1 cylinder has bad pitting took to have a rebore and they found a hole in no3 bore so needs reline, they couldn't do anything with the head as it was to far gone so brought one of eBay that was supposed to be a 998 A series but the only marks I can find are cam4810, 20A1, Z, and a B can any body help identify this head and can I fit this straight on the block without any mods, Cheers :highfive:
#2 whistler
whistler
  • 1,895 posts
Posted 02 December 2019 - 07:20 PM
Standard 998 head, later variety. Might be cheaper to dump the block and find a better one.
#3 plumbo1
plumbo1
  • 13 posts
Posted 02 December 2019 - 10:16 PM
thanks whistler, i triedto find a block but mines a auto and the manual block does'nt fit i found a A+ block but even that was a lot different so I've had the block done £320, Cheers
#4 Miki Leyland
Miki Leyland
  • 125 posts
Posted 04 December 2019 - 07:31 PM
cam4810
That's the standard head used in 998 A+ Minis. Could be leaded or unleaded depending on production year, if I'm correct.
Edited by Miki Leyland, 04 December 2019 - 07:31 PM.
#5 cal844
cal844
  • 9,734 posts
  • Local Club: TFMOC
Posted 04 December 2019 - 09:37 PM
cam4810
You are indeed correct, the only way to check is to remove valves
#6 MiniMadRacer
MiniMadRacer
  • 906 posts
Posted 05 December 2019 - 09:24 AM
I must admit I have used "leaded" heads with no adverse valve seat issues. Possibly because the heads are old and have a "lead memory"  or due to the fact that I do not rev the granny out it constantly (road car) and I do not do a humungous amount of mileage. I have never worried on a road car whether a head is leaded or unleaded, and I may have been lucky but I have had no issues
#7 whistler
whistler
  • 1,895 posts
Posted 05 December 2019 - 12:17 PM
Just for information, the crank, rods and pistons are the same as a manual.
#8 plumbo1
plumbo1
  • 13 posts
Posted 09 December 2019 - 02:28 PM
wish i had known that it would have saved me a lot of cash I still got to bye pistons the one that were in the block are well knacked, I was told that the crankhousing and the depth of the oil pump was allso different, Is it all right to use the A+ cylinder head on my A series block or is there any thing I should do to it before I fit it :tumble:
#9 gazza82
gazza82
  • 3,099 posts
  • Local Club: TMF+
Posted 09 December 2019 - 05:12 PM
Straight swap .. but might be worth checking it is flat using a straight-edge/steel rule
#10 plumbo1
plumbo1
  • 13 posts
Posted 10 December 2019 - 03:48 PM
Cheers gazza that's great will update as soon as engine reassembled :highfive:
#11 plumbo1
plumbo1
  • 13 posts
Posted 13 June 2020 - 10:28 PM
Hi all back in action after a bit of a layoff, most of engine back together but hit another problem put the primary gear back and noticed that front bush was cracked tried to get a new bush but no luck can get 1275 bush but not 1000 automatic one, i have found a new old stock primary gear with 27 teeth but mine has 29 can i change them over he also has the 2 other gears for sale,  :highfive:
#12 whistler
whistler
  • 1,895 posts
Posted 14 June 2020 - 09:13 AM
I have a set of 3. Primary gear has 33t, bush diameter is 1.5" and idler pin is 0.875" diameter. I can put pictures up if you want. Came out of a 998 auto clubman 1972/3. Also have the locating deep washer for flywheel/torque converter bolt.
If you'd rather have your primary gear rebushed try John Guess or AC Dodd. Both have experience with primary gear bushes.
Edited by whistler, 14 June 2020 - 09:21 AM.
