1996 Mpi Sportspack Steering Rack Oil ?
11 replies to this topic
#1 leepol83
leepol83
  • 1,744 posts
Posted 02 December 2019 - 07:14 PM
Hi chaps I’ve purchased a brand new steering rack from Minispares a Sportspack one, I was watching William murfit on YouTube and he was putting oil in his rack, do I need to do this or is it already filled from Minispares ???
#2 nicklouse
  • 19,058 posts
Posted 02 December 2019 - 09:10 PM
I would add some. EP90 gear oil.
#3 pete l
pete l
  • 1,536 posts
Posted 03 December 2019 - 08:46 AM
Steering racks are not filled with oil these days. They are just "greased up"
#4 absx2
absx2
  • 960 posts
Posted 03 December 2019 - 09:23 AM
But the oil does a much better job of actually lubricating, just make sure the gaskets and seals are in top condition or it will end up on the floor.
Worth doing as the rack will last much longer.
#5 pete l
pete l
  • 1,536 posts
Posted 03 December 2019 - 09:49 AM
You have to think about the steering gators that are available today, some don't last a year, so yes, your oil will one day leak out.
My greased steering rack has covered over 100,000 miles and is still good to go.
#6 Spider
  • 15,850 posts
Posted 03 December 2019 - 05:16 PM
I've always found when overhauling Steering Rack, those that were filled with Oil, except for the Bush on the Passenger's Side, usually have very little wear in them, it only when the Oi has run out, that they are worn, and that is the down side of putting Oil in them, that you have to keep a closer eye on the Gaiters and Gaskets.
200 ml of EP90.
The ones that were Greased are usually well worn. on top of this, sometimes the Gaiters can be torn and the owner not know of it.
The factory originally filled them with Oil and the move to Grease was to get around warranty issues if they leaked.
#7 leepol83
leepol83
  • 1,744 posts
Posted 05 December 2019 - 07:29 PM
Thanks for all the input, am I correct in thinking that my rack will have been greases from Minispares then ?
#8 pete l
pete l
  • 1,536 posts
Posted 06 December 2019 - 03:29 PM
It would be shameful of minispares if it was not greased up. I would take a look just in case and pack even more in there.
#9 whistler
whistler
  • 1,895 posts
Posted 06 December 2019 - 04:14 PM
Just for those not familiar with EP90. It is generally a gearbox oil.
#10 viz139
viz139
  • 727 posts
  • Local Club: Irish Mini Owners Club
Posted 06 December 2019 - 05:42 PM
The proper grease is a semi fluid grease.
I use Maxol semi fluid 00EP
Is viscosity would be very simular to Gearbox oil EP90.
http://www.maxol-lub...O and OOOEP.pdf
Unfortunately the smallest container is 3kg
https://hoaremachine...-00-grease-3kg/
I've had my tin a while but its better to have it than be looking for it
#11 Spider
  • 15,850 posts
Posted 06 December 2019 - 06:42 PM
I'm sure it would have been supplied from Mini Spares either filled with an appropriate lubricant or it would have a notice attached.
#12 leepol83
leepol83
  • 1,744 posts
Posted 11 December 2019 - 09:21 PM
Brilliant cheers guys ??
