Engine Components List.
8 replies to this topic
#1 nev100
nev100
  • Just Joined
  • 143 posts
Posted 04 December 2019 - 12:11 PM
Is there a comprehensive list of all the bits required for an engine build ??
I'll hopefully be rebuilding a new engine in the new year and whilst waiting for the block/head to return from the machine shop I'd like to start stock piling all the bits I'm going to need to get it built.
I'm aware of the big stuff - cam, timing chain, ignition etc...it's the other bits and pieces that I'll need that without which will delay the build.
Spec is 1380cc fast road.
Many thanks.
#2 nicklouse
  • 19,067 posts
Posted 04 December 2019 - 12:27 PM
well you should have already got the cam and the valves and rods and pistons. I would hope that the bearings are being supplied by the people sorting/checking the crank.
so only really your gaskets etc.
#3 nev100
nev100
  • Just Joined
  • 143 posts
Posted 04 December 2019 - 01:58 PM
Thanks Nick.
#4 the.stroker
the.stroker
    TMF Admin
  • 4,348 posts
  • Name: Dan
Posted 04 December 2019 - 02:18 PM
Moved to a more suitable sub forum.
#5 KTS
KTS
  • 2,490 posts
Posted 04 December 2019 - 02:28 PM
assembly lubricants, thread lock, DTI & cam protractor for setting cam timing, swear jar ?
#6 MiniMadRacer
MiniMadRacer
  • 906 posts
Posted 04 December 2019 - 02:33 PM
Plasters, and a Tea Pot, or cans of beer, along with a great big dollop of patience :-)
#7 MiniMadRacer
MiniMadRacer
  • 906 posts
Posted 04 December 2019 - 02:37 PM
Joking aside the Parts are not usually the big deal, its more the correct Tools for the job. I am sure there is a list on the site somewhere.. accurate Torque Wrench(s) and Feelers gauges and measuring calipers is my biggest issue
#8 Spider
  • 15,878 posts
Posted 04 December 2019 - 05:39 PM
This is a list from a car build list that I use;-
Pistons -  (set)
Piston Rings (set)
Main Bearings
Big End Bearings
Crank Thrust Bearings
Big End Fastener Set - ARP
Cam Bearings (STD)
Camshaft
Oil Pump Drive Adaptor (if needed)
Duplex Timing Chain Kit
Countersunk Screws for above
Cam Off Set Key - Check Key Needed
Cam Followers
Cam Thrust Plate
Crank Woodruff Key
Valve Guides
Hardened Exhaust Valve Seats
Inlet Valves
Exhaust Valves
Valve Keepers
Valve Spring
Valve Spring Top Hat Retainers
Valve Stem Seals - Late Type
Oil Pump
Oil Filter
Copper Washers for Oil Pipe Banjo Bolt
Dipstick
Dipstick Tube (Metal)
Oil Pressure Relief Valve Kit
Oil Filler Cap – Sealed / Unsealed as required
Rocker Cover Grommets
Head Studs - Short
Head Studs - Long
Head Nuts
Rocker Shaft
Split Pins for Rocker Shaft
Distributor Collar O Ring (A Series)
VRS Gasket Kit
Engine Gasket Kit
Conversion Gasket Kit
Timing Cover Seal
Oil Way Plugs - Main Gallery (M14)
Oil Way Plugs - Cylinder Head (5/16" UNF)
Freeze Plugs
Sealant - Gasket
Sealant - Silicon
Engine Mounts
Engine Steady Bar Bushes
Water Pump
Fan Belt
Radiator Hoses
Primary Gear Thrusts
Primary Gear Seal
This only really covers the Engine, just with the way my list is arranged, Gearbox, Flywheel & Clutch are not in that particular list.
I'd also have the Radiator Overhauled or a new one made, Overhaul the Carb and Overhaul the Distributor. To me, these items as part of an engine build, are not optional.
#9 nev100
nev100
  • Just Joined
  • 143 posts
Posted 04 December 2019 - 08:55 PM
Thanks SO much all, especially Mr.Moke Spider...
That's exactly what I needed. A shopping list that I can tick off as I get it.
Can't beat this Forum for help and advice.
Thanks again. Much appreciated
