Rear Brake Limiter
19 replies to this topic
#1 no66
no66
  • 149 posts
  • Local Club: NMCC (Norsk Mini Cooper Club)
Posted 06 December 2019 - 10:14 AM
This is on a 72 model with Dual split (diagonal, re-plumbed to front / rear split with servo)
On the rear sub there is a limiter of some sorts. Are these still availible?
Car has been sitting for about 18 years so I will be upgraging brake line etc.
Maybe easier to ditch the dual master and go for a single master with the servo on the front and an adjustable linliter for the rear.
Thoughts?
#2 Ethel
  • 25,406 posts
Posted 06 December 2019 - 11:29 AM
http://www.minispare...ck to catalogue
 It would be my preferred choice.
#3 no66
no66
  • 149 posts
Posted 06 December 2019 - 11:53 AM
Ah, thanks, was looking all over
#4 Ethel
  • 25,406 posts
Posted 06 December 2019 - 01:50 PM
I think you'll find one if you Google the number, standard fitting on single line vans & pickups - and Mokes
#5 RedRuby
RedRuby
  • 1,201 posts
  • Local Club: No
Posted 06 December 2019 - 03:21 PM
13H7757, Somerford Mini look as though they have them in stock.
#6 Spider
  • 13,899 posts
Posted 06 December 2019 - 05:43 PM
There is a number of firms who stock them.I find these the best valve they fitted in the factory. Last time I looked, Bull Motif had them. You'll likely find the one you have is in working order, they very rarely give any trouble.
By the look of the way the valve is positioned and it's associated pipework, it looks to me like the car was made as a front / rear split system.
to retain the Tandem System or go to a Single Line st up, may come down to your local registration laws, you may have to retain the Tandem set up for that.
Both systems have their pros and cons.
#7 Ethel
  • 25,406 posts
Posted 06 December 2019 - 06:21 PM
'76 was the approx date in the UK. It coincides with the change in pedals, to give the extra travel if a circuit fails, so the brake pedal sits higher than the clutch, plus different foot pads.
#8 Spider
  • 13,899 posts
Posted 06 December 2019 - 06:40 PM
For this type of Valve, that's the introduction date I also seem to have in mind too.
Also, going off the OPs Avatar Photo, the fuel tank isn't 72 either, though, they are easy enough to swap out.
#9 no66
no66
  • 149 posts
Posted 09 December 2019 - 11:38 AM
Thanks for the replies.
Yes, the privious own put in a bigger tank. First time registered 72 here in Norway.
As for the front / rear, yes it is. i was mixing up with my brothers 76. There we had to swap pipes when we put discs and servo on or it would only brake diagonally :-)
How hard is it to service this MC? Been sitting for a long time.
Edited by no66, 09 December 2019 - 11:51 AM.
#10 DeadSquare
DeadSquare
  • 2,756 posts
Posted 09 December 2019 - 12:09 PM
How long, is "long" ?
Brake fluid slowly absorbs water, but I have often had no trouble bringing the system back into use after up to 5 years, having purged the old fluid  very thoroughly.
If you haven't got a workshop manual, take lots of photos as you take the Master cylinder apart.
#11 no66
no66
  • 149 posts
Posted 09 December 2019 - 12:15 PM
At least 15 years sat still. It moves, but thinking of the seals etc.
#12 nicklouse
  • 17,935 posts
Posted 09 December 2019 - 12:35 PM
it bet it will be fine.
#13 no66
no66
  • 149 posts
Posted 09 December 2019 - 12:46 PM
Ok, I will have a really good bleed.
Will be getting new rear cylinders, and will probably have to service the front calipers. Haven't had a look yet.
#14 Dusky
Dusky
  • 5,322 posts
Posted 09 December 2019 - 01:09 PM
Might be worth changing the flexi hoses while you're at it too. Popping a flexi isnt a fun experience ?
#15 nicklouse
  • 17,935 posts
Posted 09 December 2019 - 01:14 PM
if you are changing most of the parts when you come to bleed it look for little bits of black in the fluid. if there is it will be from the rubber...
