Is it possible to fit an A+ series crownwheel and pinion/diff into an A box ? even with some small modifications ?
Diff is a 3.1 CWP (not sure what it is out of) into a "A" Austin 1300GT box.
Posted 06 December 2019 - 01:46 PM
Posted 06 December 2019 - 01:56 PM
sure. but you do need to make some decisions on what parts you want to use and use the appropriate parts.
the easiest is just to swap the CWP over to the existing diff set up.
Posted 06 December 2019 - 03:17 PM
I don't see any problem, presume it's for the better ratio?
As above, just swap the bits you need to avoid driveshaft differences.
Posted 06 December 2019 - 05:23 PM
Posted 06 December 2019 - 05:30 PM
Unless you have the later main bearing retainer you will have to remove some metal from the inside of the early one as the 3.1 pinion is a larger diameter.
Posted 06 April 2020 - 03:02 PM
anyone got some more information on this machining ? link to a video etc ? just want to have a look whats involved before I pull the trigger.
Posted 07 April 2020 - 09:46 AM
My winter rebuild included fitting a 3.1 CWP to my A series 'box. The bearing retainer only just touched the pinion slightly so removing enough to clear was very easy. I did it with a die grinder but it is such a small amount you could probably manage with a decent half round file. Fit the 3.1 pinion and then try the bearing retainer in, you will see how little needs to come off.
Posted 07 April 2020 - 09:53 AM
heres a pic of each type, you just need to take the inner part out to clear the pinion by a couple of mm.
http://www.guess-wor...play.htm?id=247
http://www.guess-wor...play.htm?id=246
