Rc40 Exhaust Fitting.
4 replies to this topic
#1 Wizzalong
Wizzalong
  • 100 posts
Posted 08 December 2019 - 08:32 PM
I'm having problems fitting RC40 exhaust '93 1275 Cooper SPi, I have a Maniflow lcb, Twin silencer with cat, Stainless steel down the middle twin tailpipes, Everything seems fine until reaching rear subframe mounting points, I have the fitting kit but nothing lines up, I imagine I can't use the original hangar but the mounting rubber supplied is offset on subframe not centre and although i have straightened the slight twist on one hangar it cannot be used successfully because it's trying to pull it back to one side, Does anyone have experience of fitting this set up?
I realise the rear of subframe will need to be drilled for mounting bobbins (may devise a bracket so exhaust sits on rather than hangs)
Thanks, Mike.
#2 nicklouse
  • 17,940 posts
Posted 08 December 2019 - 09:15 PM
never had an issue.
maybe pictures of your issues would enlighten us as to how you have assembled it.
#3 Wizzalong
Wizzalong
  • 100 posts
Posted 18 December 2019 - 08:18 PM
#4 Wizzalong
Wizzalong
  • 100 posts
Posted 18 December 2019 - 08:20 PM
#5 Wizzalong
Wizzalong
  • 100 posts
Posted 18 December 2019 - 08:22 PM   Best Answer
