Hi All,
I'm in the process of replacing radius arms and manage to shear the bolts off in the captive nuts (DAMN) so the subframe is coming out.
My question is, has anyone done this? Do you need to interrupt the fuel system? Haynes says you need to remove the fuel filter, disconnect it and block the lines. BUT it looks like the frame will come out without having to disco the filter.
Has anyone done this to their SPI?
