Yeah I hear the fuel pump priming.
Yeah I do have a Haynes manual, will be going through it later...
When the lights were working the flash only worked on the two inner spots.
Attached are the light switches I have.
I've also recorded a video of me starting it now... makes a few less noises than before.
Thanks for putting up pictures. This may take a while...When you turn the ignition on but don’t try and start the car, do you hear the fuel pump priming at the rear of the car? (It’s inside the petrol tank). If you hear that, that means the power is getting there and the fuel pump relay is working.
That block of fuses behind the air filter is an aftermarket change to replace the standard nest of inline fuses that are usually there. It can be a sensible modification but it means you’re likely going to have to get familiar with the wiring diagram and work out which fuse does what for yourself. Do you have a Haynes manual?
I can see what looks like an additional relay on the left hand side of your engine bay. One looks to be on the factory fit mounting which would be to work 2 standard spots. The other relay will likely be to run the other two lights. It’s possible that relay too could be wired to come on with flash/main beam or as I previously mentioned as front fogs. When working correctly you will hear them click on and off when flashing your headlights.
Did you say whether you had any additional light switches inside the dash? Trying to work out if the additional lights are wired as fogs or spots.
Edited by KnightOwl738, 01 January 2020 - 06:05 PM.
