Inner Pot Joint Bearing
Posted 31 December 2019 - 09:07 PM
I recently bought a 1992 mini with no engine, however the drive shafts where still fitted with the inner pot joint bearings attached, during transit I think a couple of the bearings fell out. Is there anywhere I can buy just the bearings? don't want to have to replace the whole lot at this stage.
Regards
Posted 31 December 2019 - 09:48 PM
Posted 31 December 2019 - 09:57 PM
Posted 01 January 2020 - 01:57 AM
If you mean the 6 x ball bearings per side, you can get them and they are 21/32"
https://minisport.co...-for-inboard-cv
Posted 01 January 2020 - 02:08 AM
You mean if the pot joints are original then that is the size they were originally. But there are 3 standard oversized balls specked as OE parts. And if the pots are no longer OE spec they could be a different size. I would just replace the whole joint.
Posted 01 January 2020 - 04:27 PM
If the bearings were visible on the end of the shafts then you’re missing half the joint anyway, presumably the other half was left in the (missing) gearbox.
