New Coil And Module - Sluggish / Loose Feeling Accelerator
8 replies to this topic
#1 minimininut
minimininut
    Look Out For My Haynes Minature Engine Install Project
  • 830 posts
Posted 02 January 2020 - 03:36 PM
Hi MiniForum,
My coil died just before Christmas on my 1988 mini with after market non-ballast ignition system.
Minispares advised GCL143 and the associated module - both now fitted:  https://www.minispar...sic/GCL143.aspx
He's running ok but sometimes the accelerator feels stiff (I think at low revs maybe) and he's a bit sluggish and then throttle goes loose under my foot (bit hard to explain!)
After some investigation what came off was this Lucas one - DLB198  -  which weirdly does come up when you search for GCL143 on the internet: https://rimmerbros.c...ASABEgKoofD_BwE
Any difference between these two coils that would explain sluggishness and odd throttle feeling?
Thanks ever so much
#2 cal844
cal844
  • 9,736 posts
  • Local Club: TFMOC
Posted 02 January 2020 - 04:02 PM
How old is the fuel your using? What dashpot oil are you using?
#3 minimininut
minimininut
  • 830 posts
Posted 02 January 2020 - 04:06 PM
Fuel 2 weeks! Not sure what dashpot oil but AA guy was happy dashpot was all good when checking stuff before diagnosing coil as the likely problem.
#4 cal844
cal844
  • 9,736 posts
  • Local Club: TFMOC
Posted 02 January 2020 - 04:43 PM
Check the resistance of the coil to see if it's up to spec, it's either electrical or fuel.
#5 minimininut
minimininut
  • 830 posts
Posted 02 January 2020 - 05:13 PM
Thank you for your help, it’s appreciated.
I don’t have equipment or the mechanical know how to check resistance- I’m really just wondering if there is a difference between these two coils that would explain the sluggish / loose feeling throttle having replaced the part.
Is it doing any harm to my car driving him while he’s like this?
#6 Dusky
Dusky
  • 5,322 posts
Posted 02 January 2020 - 05:23 PM
Did you reset the timing after fitting thr new module?
#7 minimininut
minimininut
  • 830 posts
Posted 02 January 2020 - 05:32 PM
A garage did it - they’re closed now so I don’t know but can ask another day. Would that explain the symptoms?
Any idea if it’s ok to drive as it is.
#8 cal844
cal844
  • 9,736 posts
  • Local Club: TFMOC
Posted 02 January 2020 - 07:14 PM
It potentially can do damage if it's bad enough, personally I'd get the garage to double check the timing.
My dad does the timing by ear, feel and road testing, on a standard engine.
Your car will need retimed if you have converted from points type ignition
#9 minimininut
minimininut
  • 830 posts
Posted 02 January 2020 - 08:55 PM
Fab, thanks, I'll not risk it then!
