Running On 3 Cylinders
Best Answer tamlamotown123 , 06 January 2020 - 07:58 PM
Hi thanks for everyone who replied to my post, some useful ideas and solutions for me to work through, just waiting for a warmer dry day to try them out best regards to all
Go to the full post
8 replies to this topic
#1 tamlamotown123
tamlamotown123
  • 95 posts
Posted 03 January 2020 - 02:02 PM
Hi any suggestions on my issue?
1293 twin Su's new 23D dizzi,new plugs/leads,new loom,orig alternator and coil. has run ok for about 500 miles.
Problem is running on 3 cyls most of the time but will occasionally run on 4 for 20/30 secs, av tried removing each plug lead
one at a time but makes  no difference.plugs are gaps are ok, alternator is charging, dashpots are free to move.
#2 DeadSquare
DeadSquare
  • 3,382 posts
Posted 03 January 2020 - 02:11 PM
Clean the original dizzi,  put it on a radiator to dry for a day, check the cap for cracks or buy a new one, fit it, time it, spray it with WD40 and see if there is any difference.
#3 slidehammer
slidehammer
  • 1,212 posts
  • Local Club: LSMOC
Posted 03 January 2020 - 02:15 PM
Might be worth compression testing the engine, check the compression is fairly even across the cylinders and checking that the tappets are set properly and not holding a valve open.
#4 MiniMadRacer
MiniMadRacer
  • 906 posts
Posted 03 January 2020 - 02:50 PM
Have a good look at the Rotor arm, and the 4 contacts it "touches" inside the dizzy cap. Pattern rotor arms are notoriously sh.... and I have "eaten" a few in about 500 miles
#5 floormanager
floormanager
  • 804 posts
  • Local Club: Mini Club Sussex
Posted 03 January 2020 - 07:57 PM
I had a recent experience of an engine only running on two cylinders. Convinced the new head gasket had blown, compression test ruled that out.. New distrubutor and components.  All new on the HT side. Changed to twin carbs, rebuilt the original HIF44, still would not run. Changed the condenser and off it went!!  I could not believe it.
#6 sonscar
sonscar
  • 3,256 posts
Posted 04 January 2020 - 02:19 PM
I had similar symptoms with a leaking inlet gasket,Steve..
#7 Tones61
Tones61
  • 441 posts
Posted 05 January 2020 - 01:17 PM
Poss wear in dizzy shaft,sometimes not opening points on due to play in shaft
Edited by Tones61, 05 January 2020 - 01:17 PM.
#8 tamlamotown123
tamlamotown123
  • 95 posts
Posted 06 January 2020 - 07:58 PM   Best Answer
#9 Tones61
Tones61
  • 441 posts
Posted 17 January 2020 - 04:00 PM
any news on this mate :-)
