No Heat!
10 replies to this topic
#1 duf72
duf72
  • 13 posts
Posted 04 January 2020 - 04:03 PM
Hi all, I have a bit of a puzzle here. Have a 91 Mayfair, but I am getting no heat delivered inside the car. I have checked for blockages, airlocks, removed and checked heater matrix, changed the thermostat but still no joy. The pipes to the matrix are both heating up, but with the fan on it blows out a very slightly warm flow of air.
There is plenty of heat being produced, outside the car I can feel a lovely hot airflow being pushed through the rad ( by the way the engine fan is constantly on?).
Any ideas?
#2 mercenary62
mercenary62
  • 359 posts
  • Local Club: mini clan
Posted 04 January 2020 - 04:29 PM
Any ideas?
itl be the heater matrix blocked mate  , try flushing it through with a hose might do the trick, if not replace the matrix
Edited by mercenary62, 04 January 2020 - 04:31 PM.
#3 duf72
duf72
  • 13 posts
Posted 04 January 2020 - 04:39 PM
Had all the matrix out, and flushed it too. It all looked in pretty good shape though, but I guess the problems are not always visible!
#4 InnoCooperExport
InnoCooperExport
  • 372 posts
  • Local Club: Mini Seven Club Nederland
Posted 04 January 2020 - 05:30 PM
checked the heater tap actually opens?
#5 duf72
duf72
  • 13 posts
Posted 05 January 2020 - 02:14 PM
#6 duf72
duf72
  • 13 posts
Posted 05 January 2020 - 02:16 PM
I checked it when removed, it did open, but I think I will check it in situ, make sure the cable is opening it fully.
Thanks for that!
#7 DeadSquare
DeadSquare
  • 3,382 posts
Posted 05 January 2020 - 02:47 PM
If you can hang on a bit, I have found that they usually work best, in the summer.
#8 duf72
duf72
  • 13 posts
Posted 05 January 2020 - 03:42 PM
#9 duf72
duf72
  • 13 posts
Posted 05 January 2020 - 03:43 PM
#10 Spider
  • 15,873 posts
Posted 05 January 2020 - 06:22 PM
Thanks for that!
If the Rubber Hoses are getting hot, then I'd say it's reasonable to say the Tap is working.
I'd suggest as others here have, flushing the matrix, but doing so by disconnecting the hoses in the engine bay and doing it from there.
#11 InnoCooperExport
InnoCooperExport
  • 372 posts
Posted 06 January 2020 - 10:52 AM
Whoops, missed that the pipes did heat up. If they do that, then the tap should work.
