Throttle Body Gasket Spi
Best Answer Pops_Guild , 05 January 2020 - 12:54 PM
If you mean the one pictured, then you're in luck there's one for sale on Ebay atm...
https://www.ebay.co....0sAAOSwN4VduHjs
But from your description of between inlet manifold and injector housing you could mean LZV1101EVA, which is plastic and available still.
If you have stripped down your entire throttle body assembly then you will need to replace any gaskets, they are essential as you'll have fuel escaping out of the system where you don't want it too...
Go to the full post
2 replies to this topic
#1 MatthewsDad
MatthewsDad
  • 901 posts
Posted 05 January 2020 - 09:37 AM
Hi, the plastic gasket part number JZX3064EVA that sits between the injector housing and the inlet manifold is showing as NLA on the main suppliers' sites. Does anyone know of a possible source? Is a plastic gasket essential - just thinking about fabricating one if I can't source original spec.
While I have the throttle body apart is there anything I should replace / recondition for preventative maintenance?
Many thanks.
#2 Pops_Guild
Pops_Guild
  • Just Joined
  • 363 posts
Posted 05 January 2020 - 12:54 PM   Best Answer
#3 MatthewsDad
MatthewsDad
  • 901 posts
Posted 05 January 2020 - 10:38 PM
I've picked up the eBay item, really pleased, thank you for pointing me in the right direction.
