Help Please, To Identify My Camshaft.
Best Answer DeadSquare , 06 January 2020 - 01:43 PM
That's a Kent cams version of the cooper spi cam.
Ac
Thank you;  I should have twigged that the 'K'clgc indicated Kent.
Go to the full post
6 replies to this topic
#1 DeadSquare
DeadSquare
  • 3,382 posts
Posted 06 January 2020 - 09:48 AM
My daughter-in-law recently felt that my old age would be improved by reducing the number of boxes in the garage.
All "The Knobbly Bars" were put in one box.
The knobbly bar in question's 1/2" inlet lobes have a lift of .259" and the .265"  exhaust lobes are more lumpy that the inlet.
The oil pump drive slot has been cut through a lightly stamped "370??A"  and then badly stamped  with "KCLGC 10230".  there is also "10042" stamped in small figures.
#2 MiniMadRacer
MiniMadRacer
  • 906 posts
Posted 06 January 2020 - 10:00 AM
Sounds like it could be a 1275 A+ SPI one, but I am sure others may know better as I have very little knowledge of the fuel injected minis compared to their carb counterparts
#3 ACDodd
ACDodd
  • Mini Docs
  • 2,836 posts
Posted 06 January 2020 - 01:33 PM
Ac
#4 DeadSquare
DeadSquare
  • 3,382 posts
Posted 06 January 2020 - 01:43 PM   Best Answer
Ac
Edited by DeadSquare, 15 January 2020 - 10:52 AM.
#5 DeadSquare
DeadSquare
  • 3,382 posts
Posted 15 January 2020 - 10:52 AM
Ac
UPDATE:
Kent tell me that it is a Race Cam that they grind for MiniSpares,  as used in the "Mighty Mini Race Series"
#6 OzOAP
OzOAP
  • 401 posts
Posted 15 January 2020 - 11:00 AM
As AC said, it is a std SPI profile. It is the cam that you have to use in Mighty Minis, (unless you are Tellos mate, then you can use anything). Kent ground some after problems with Rover supply.
#7 ACDodd
ACDodd
  • Mini Docs
  • 2,836 posts
Posted 15 January 2020 - 12:59 PM
As it happens I am currently working on a spec cam for mighty minis this year!
Ac
