Thermostat Housing For 1275 Engine
5 replies to this topic
#1 mercenary62
mercenary62
  • 359 posts
  • Local Club: mini clan
Posted 10 January 2020 - 03:55 PM
so just started sorting through a mini i bought recently needs a bit of tlc , it was a mini city e ,but someone bunged in a 1275 metro engine , problem is the top radiator hose has a bit of a restriction as its kinked slightly is there another housing that will sort this out for a smoother bend on the hose cheers
#2 nicklouse
  • 19,058 posts
Posted 10 January 2020 - 04:05 PM
they are all the same.
you need the longer top hose. which may need shortening a little bit if it was for the 1275GT body.
#3 Ethel
  • 26,791 posts
Posted 10 January 2020 - 04:11 PM
The thermostat housing sit at different angles on small & large bore engines, the hose adapts for the difference. Unless it still has the Metro housing, which has a flat top and an air bleed pipe that would need a header tank or blanking off.
#4 mercenary62
mercenary62
  • 359 posts
Posted 10 January 2020 - 04:21 PM
is this what u mean nick, http://www.minispare...px|Back to shop
#5 nicklouse
  • 19,058 posts
Posted 10 January 2020 - 04:22 PM
yep
#6 mercenary62
mercenary62
  • 359 posts
Posted 10 January 2020 - 04:29 PM
yep
thanks again nick
