Crank-Clutchhub Depth Measurement
3 replies to this topic
#1 dotmatrix
dotmatrix
  • 441 posts
Posted 10 January 2020 - 05:55 PM
Does any of you have a measurement for how far in on the end of the crank the hub and clutch should sit?
#2 dotmatrix
dotmatrix
  • 441 posts
Posted 10 January 2020 - 06:25 PM
The end of this guys crank taper seems to be flush with the small edge in the clutch hub.
#3 nicklouse
  • 19,062 posts
Posted 10 January 2020 - 06:37 PM
The crank should be some below the crank washer face on the fly wheel or you will never tighten the fly wheel on.
I am not sure there is an actual measurement. But if there is the Sipder will know it.
#4 dotmatrix
dotmatrix
  • 441 posts
Posted 10 January 2020 - 09:37 PM
yes I realised this and it is below that, but not by a lot.
new material has been put on the the crank taper so wanted to measure where it ended up.
