Get Steering Arm Dowel Out
9 replies to this topic
#1 Benito_S6
Benito_S6
  • 89 posts
Posted 11 January 2020 - 04:29 PM
Anyone know a way of getting a steering arm dowel out of a steering arm?
#2 Chris1275gt
Chris1275gt
  • 1,052 posts
Posted 11 January 2020 - 05:28 PM
Spray a penetrating fluid let it soak get a blow lamp on the hub not the dowel and a pair of mole grips to twist it, in that order.
#3 Spider
  • 15,865 posts
Posted 11 January 2020 - 06:23 PM
You can use a Dowel Puller if you have access to one.
If you want the Arm and not worried about the dowel, you can grease up the arm and weld an old bolt to the dowel. Often just the heat from welding is enough to loosen them.
Or you can Tap a Thread in the Dowel and screw in a bolt. Grip the Bolt in the vice and tap the Arm off.
#4 unburntfuelinthemorning
  • 2,003 posts
Posted 11 January 2020 - 07:55 PM
What's a dowel puller look like?
#5 Spider
  • 15,865 posts
Posted 12 January 2020 - 12:27 AM
I'll try and remember to snap off a photo of mine.
#6 nicklouse
  • 19,063 posts
Posted 12 January 2020 - 12:43 AM
in the past i have used
Attached File  ae235.jpg   12.72K   3 downloads
to hold the inside.
Edited by nicklouse, 12 January 2020 - 12:44 AM.
#7 DeadSquare
DeadSquare
  • 3,382 posts
Posted 12 January 2020 - 09:28 AM
Which are you wanting to save, The arm or the dowel ?
#8 wile e coyote
wile e coyote
  • 1,230 posts
Posted 12 January 2020 - 11:12 AM
to hold the inside.
That's bodgetastic genius!!!
#9 mini13
mini13
  • 3,811 posts
Posted 12 January 2020 - 05:50 PM
Ha! the Rawl bolt is a good one,
If its not too stuck you can push in a bit of tight fitting hose and screw somthing into that to expand the hose to fit,
#10 Benito_S6
Benito_S6
  • 89 posts
Posted 14 January 2020 - 01:24 PM
Just to let you all know sorted it. Had a mole grip round it and couldn’t get it. Heated it no joy. Then put it in a vice and knocked it out with a punch. Little things always give hassle don’t they.
Thanks for the replies everyone.
All the best
